Primary Server may not find the Secondary Server on startup if the runtime is started simultaneously on both systems when using the hardware redundancy mode.
When the runtime is started simultaneously on both the primary server and the secondary server when using the hardware redundancy mode, the primary server may not find the secondary server and vice versa. After restarting the runtime on the secondary server, the connection is established correctly.
An issue has been addressed in the runtime where the hardware redundancy mode prevented synchronization when the primary server and secondary server were looking for each other during startup
Issue Number: 36377
Fixed on Date: 24.5.2016
Versions: 7.50 0 BUILD 28986
