Platform setup for zenon 12
Platform setup for zenon 12 provides more information and convenience.
When selecting components for installation, you now receive information on the installation status and necessary prerequisites for each component as a tool tip.
In the packages for installing the zenon Software Platform you will now also find Device Management Interface components. These can be activated by default in the respective installation packages. They can be selected or deselected.
These components are used on the client/device by the Device Management of IIoT Services. This allows zenon projects to be distributed over devices. Setup installs those devices that are required on a device to work with Device Management.
If installation is canceled due to an error, a comprehensive LOG file can now be created by the System Information Collector.
To do this, click the button
Collect system information for support. The SIC collects all relevant data. You can use this log for your own analysis and, if necessary, also send it to COPA-DATA Support.
When installing the Report Engine the folder for the SQL Server database can now be defined.
Note: There must not yet be an instance of the Report Engine available.
The HTML Web Engine Compiler is now also available as a 64-bit application. This means that even very large projects with large RAM requirements can be started without any problems. It also makes it possible to compile extensive projects that cannot be compiled in a 32-bit architecture due to lack of memory.
Screens of type HTML are now based in the Service Engine on the Microsoft component WebView2.
In this way, the content of complete websites can be integrated in the Service Engine
When installing the Jetter driver, the files for the required additional software are also installed.
Storage location:
  • Windows 64: C:\Windows\SysWOW64
  • Windows 32: C:\Windows\System32
The following are required:
  • Jet32Ex2.dll
  • JetIP32.dll
  • Jet32Controllers.xml
  • Jet32Controllers.bin
With GraphQL Interface a new service is available for 1st and 3rd party clients. It provides metadata and process data via an easy-to-use interface. Report Engine serves as the data source. The existing connector functions are used for the query. Access is read-only. With GraphQL Interface, individual applications can be created and existing applications can be extended.
The following MongoDB programs are included in the setup:
  • MongoDB 6.0.3
  • MongoDB Shell 1.6.0
  • MongoDB Database Tools 100.61
Update for add-in wizards during Build Setup (F 290975)
When importing build updates for zenon Add-In Wizards are now updated automatically. Manual configurations or updates are no longer necessary.
The entry
UPDATE=1 in the zenon6.ini file is set automatically and is the default value.
Removed Pharmaceutical Wizard from the zenon Software Platform (S 255325)
The Pharmaceutical Wizard is no longer included in the scope of delivery from version 12.
Item ID: 250975
Version: 12.00 Build: 153415
    • Vulnerable zlib library in zenon setup
      Description zenon Softwareplatform 11 and 12 contained outdated zlib components that were found to be vulnerable. These have been replaced with latest zlib version 1.3.3. To benefit from this fix: Update your zenon Software Platform to the latest ...
    • Platform Setup 11: Comparison Tool starts with "Unhandled UI Exception" popup error
      Description When starting the Comparison Tool from the Startup Tool, an "Unhandled UI Exception" is displayed. The Comparison Tool cannot be started. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the ...
    • Checklist: Software Platform installation fails
      Time estimate: 30 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. Checklist usage: #. [Quick ...
    • Checklist: Software Platform build update fails
    • FAQ: Are products in the zenon product platform compatible with the latest Microsoft Updates?
      COPA-DATA develops and maintains products in the zenon Software Platform on systems that have all the latest updates installed. Also automated and manual QA tests are executed continuously on non-development systems that have all the latest updates ...
