The zenon Process Gateway
AccessIEC870Sl as an
IEC 60870-5-101 slave with balanced transmission discarded the serial receive buffer when processing confirmation frames (or single character control). If there were already other frame characters in the buffer, they could not be processed. For example, this could result in an execute command not being executed.
The issue has been addressed and the buffer is no longer discarded.
