PFS API crash when shift points are read from timetables with subordinate timetables
New Methode was implemented for API:
GetParentSchedule in PfsSchedules
This Methode Returns the parent schedule if the schedule collection is in a child parent. In this case the Parent property is null.
The parent of the object "PfsSchedule" can either be a PfsGroup or a PfsSchedule, never both.
Issue Number: 133181
Fixed on Date: 17.5.2018
Versions: 7.60 0 BUILD 49005 | 8.00 0 BUILD 48821
    • PFS switching points get corrupted.
      Summary From a certain moment on PFS switching points disappear after creation and also existing ones disappear. Description From a certain moment on PFS switching points disappear after creation and also existing ones disappear. Solution An overflow ...
    • Checklist: Process closes unexpectedly (***Reproducible***)
    • Checklist: Process closes unexpectedly (***Non-reproducible***)
    • zenon - Addins - Codesnippet - Read version from within
      There seems to be no zenon-API-property to read the Addin-version (= AddInInfo.cs - [assembly: Addin("AddInName", "x.x")] ) from within the Addin. But it seems possible to read it using reflection on the assembly-attributes. => C# Code-snippet ...
    • Engineering Studio crash: PFS Copy / Paste of corrupted Schedule (error: is linked with invalid variable)
      Description A schedule is copied in the PFS that contains missing or invalid variables. During this process, the Engineering Studio crashes. This behavior has been changed. Corrupted schedules no longer cause a crash during copying. While generating ...
