PasswordValidated event in AddIn can not prevent a password to be changed.
User can modify his password although the “PasswordValidated” event prohibits it. This error has been fixed.
In ProjectServiceExtension Add-In a user should be prevented by the “PasswordValidated” event from modifying his password. The property "IsSuccessful" in the event parameter is set to "false" as expected. That should prevent the user to change his password. However, the user can still modify his password.
The error was caused by a general problem with events that include modifiable parameters of type "enum" or "simple". This has been fixed. The “PasswordValidated” event now works as expected.
Item ID: 267311
Version: 12.00 Build: 162090
Version: 11.00 Build: 161931
Version: 10.00 Build: 162215
