Parts of gannt curves are not displayed in ETM
In the Extended Trend parts of a Gantt curve are not displayed correctly. This has been fixed.
In the Extended Trend parts of a Gantt curves, where data has been read back from SQL-evacuated archives, are not displayed. With data from an ARX file, the curve is displayed correctly. SQL files used a different definition of the end time.
The way data is interpreted for Gantt curves has now been changed. It is now independent of the data source. If there is a value for the Gantt curve in the display area, the curve is drawn as follows, depending on what occurs first:
  • up to the current time
    or
  • to the right edge of the display area
Item ID: 260265
Version: 11.00 Build: 157700
    • ETM: Cursor output window only shows data until "now", not from curves that are in the future.
      Description If a time filter in the ETM is set in the future, the cursor output window only displayed data until "now", but not from curves that are in the future. The issue has been addressed and now the correct values are displayed in the cursor ...
    • ETM - Multi-select and multi-edit possibility for trend curves
      Summary ETM allows multi select and multi edit for trend curves. Description From now on, both in the Engineering Studio as well as in the Service Engine, several curves of Extended Trend can be edited at the same time. To enable quick changes, ...
    • Not all curves of Block Arrays are displayed in ETM
      Summary Curves were not reset correctly. Therefore while drawing them, they were not handled correctly. Description Curves were not reset correctly. Therefore while drawing them, they were not handled correctly. Issue Number: 139498 Fixed on Date: ...
