Output window: "Report Viewer: export/print" function provides incorrect warning in the output window
The "Report viewer: export/print" function issues incorrect warnings in the output window. This has been fixed.
Under certain conditions, the "Report viewer: export/print" function issues incorrect warnings in the output window. This happens if "Output as PDF" with "Export report in" "Filename from variable" is first selected in the configuration for "Target" without linking a variable and then changing the setting for "Target" to "Output on printer". When creating the Service Engine files, a warning is displayed in the output window: "Unable to find a variable linked with the function 'ReportViewer-print." This refers to the discarded configuration of the output as PDF. This warning is misleading and should not be displayed.
This behavior has been changed. After changing the configuration, a warning relating to discarded configurations is no longer displayed.
Item ID: 279881
Version: 14.00 Build: 239777
    • FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
      A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
    • FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
    • Report Viewer: export/print function -> Execution ONLY on Primary Server
      Description The Report Viewer: export/print function could only be executed on a Primary Server. All other fields were grayed out and could not be selected. The default Execution setting has now been changed to Current computer. To benefit from this ...
