Opening the lot filter in the Report Viewer on a client no report is displayed
When opening the lot filter in the Report Viewer on a client, no report is displayed. This has been fixed.
In the Report Viewer, if different lots are opened on the server and client, no report is displayed on the client. If the same lot is selected on the server and client, the report is displayed correctly.
This is because the lot list is requested unfiltered from the server and then filtered using the local value of the lot filter variable. The lot filtering of the archive data on the server is therefore carried out using a different variable value. This means that the client's time filter and the server's lot filter do not match.
This behavior has been modified. The correct reports are now displayed on the Report Viewer client.
Item ID: 271093
Version: 12.00 Build: 180966
Version: 11.00 Build: 182164
Version: 10.00 Build: 195250
    • Opening the lot filter in the Report Viewer on a client shows different report
      Summary When a report is displayed in the Report Viewer via the lot filter in the client, a different report is displayed than configured. Description If a report for a lot is created in the Report Viewer via the lot filter on the server and another ...
    • FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
      A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
    • FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
