When opening a Batch Control screen, properties of existing recipes are loaded in order to display this information in the list. Depending on the number of existing recipes and configuration of the screen switch function this may take a while as the information has to be read from the harddisc.
The loading time could be reduced by improving the way in which the required information is read and loading all the information into memory on RT startup. As all the required data is already in memory when opening the screen there“s no need to read it from the harddisc. Therefor opening a Batch Control screen is now much faster.
Be aware that if you open the screen directly after RT startup (before the information was read), you will still recognize the dalay.
Issue Number: 37042
Fixed on Date: 6.10.2016
Versions: 7.11 0 BUILD 32428 | 7.20 0 BUILD 32414
