OPCUA32: OPC UA Client driver does not connect with username / password anymore if the server does not provide a certificate (e.g. as a nano embedded server)
The attempt to connect to an OPC UA Server with username and password fails when connecting to a server which does not provide a certificate. The error message reads: "Can not validate URI because proper endpoint has no certificate". But for Nano Embedded Server it is allowed that no certificate is provided.
This behavior has been changed. Connection is now possible without server certificate.
Item ID: 258311
Version: 11.00 Build: 117823
