OPCUA32: Fallback to ConditionRefresh should also occur when the OPC UA Server returns 0x80400000 - BadNotImplemented on the Call of ConditionRefresh2
Fallback to ConditionRefresh does not work correctly for specific OPC UA Server. This has been fixed.
When the OPCUA32 driver creates monitored items for event notifier variables, it calls the ConditionRefresh2 method after creating the monitored items. It may fall back to calling the more generic ConditionRefresh method, if the server does not support ConditionRefresh2. If however the OPC UA
Server server returns BadNotImplemented the OPCUA32 driver does not execute the expected fallback
to ConditionRefresh.
This behavior has been modified. In the case of a BadNotImplemented response from the server to ConditionRefresh2,
the OPCUA32 driver executes a fallback to ConditionRefresh.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 11
or higher.
Item ID: 270764
Version: 14.00 Build: 257014
Version: 12.00 Build: 272744
Version: 11.00 Build: 272743
How to setup the zenon OPC UA Process Gateway with a self-signed certificate
This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
