OPCUA32: driver crashes on driver start command under specific circumstances
The OPCUA32 driver closes unexpectedly under specific timing conditions when the driver is stopped and started using driver command functions.
Issue Number: 198912
Fixed on Date: 6.11.2019
Versions: 8.00 0 BUILD 62073 | 8.10 0 BUILD 62573
    • OPCUA32: driver crashes on driver start command under specific circumstances
      Description When stopping and starting the OPCUA32 driver via driver command functions, the driver is closed unexpectedly if the commands are executed in a fast time sequence. This behavior has been fixed. To take advantage of this fix: Update to the ...
      Description When stopping and starting the OPCUA32 driver via driver command functions, the driver is closed unexpectedly if the commands are executed in a fast time sequence. This behavior has been fixed.  To take advantage of this fix: Upgrade to ...
    • Checklist: Engineering Studio cannot start or closes unexpectedly
    • AddIn does not start
      Check the Logs in DiagViewer. If it shows an ERROR in the GENERAL module which shows the exception: Scada.Internal.DotNetAddInExtension.AddInIntegration.Startup Cannot startup Add-In .NET Extension for instance id 'e1d3....'. Exception ...
