The OPCUA32 driver should usually not write
structures if the structure is not advised. This applies to variables that have
never been advised. However, if the variable has been advised once, a value can
be assigned to the variable via the function "Write setpoint". This works
even if the variable is no longer advised. The other values of the structure
are then filled with the last known values. These may therefore be obsolete.
This behavior has been modified. Variables in structures that are no longer advised can no longer be assigned a value.
