OPCUA Client - Hide the "Mode" property does not change the mode for old application using "Synchronous" mode
When opening a zenon Logic project in version 11 or higher the output window shows for the OPC UA Client an error message: "Synchronous mode is not supported".
However, the "Mode" option in the "Group" dialog for configuring this mode is not available. It has been removed with version 11.
The use of the removed option has been fixed.
  • Update your zenon Software Platform to the latest build of zenon 11 or higher
Item ID: 257403
Version: 11.00 Build: 111398
