OPCUA Client Driver: Extension Objects "Switching Time" in "Schedule" do not work properly
In the OPCUA client
driver, setting a value other than 0 for "Switching Time" in "Schedule"
leads to an error. All variables become invalid. These variables can be set to 0 again with another OPCUA client.
They are then spontaneous again.
Cause:
The server sends numerical data, while the OPCUA32
driver expects a zero-terminated CharArray. Sending 0 is therefore interpreted as an empty string. Any
other value leads to an error.
This error has been fixed. Values other than 0 can be set for "Switching Time".
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 269327
Version: 12.00 Build: 180966
Version: 11.00 Build: 176384
Version: 10.00 Build: 176923
Checklist: Smart Client does not work
OPCUA Client - the connection can't be recover after some time
Description After some time the OPCUA Client lost the connection and could not reestablish it anymore. The issue has been addressed and the driver connection is now stable. To benefit from this fix: Update your zenon Software Platform to the latest ...
OPC UA driver is not importing variables and extended objects correctly after update to zenon 10 build 111092 from build 94554.
Description The OPC UA driver does not import variables and enhanced objects correctly. Especially the import of more than one structure is affected. The error occurs in version 10 with builds higher than 94554 and in version 11. Up to build 94554 ...
