OPC UA Process Gateway may result in a WERFAULT error on reloading the runtime
When reloading the runtime the OPC UA Process Gateway may produce a WERFAULT error in certain circumstances. The user interface of the OPC UA Process Gateway continues to run, however client connections are disconnected and not able to reconnect.
An issue has been addressed in the OPC UA Process Gateway where under certain timing conditions the shutdown takes too long during reload of the runtime and could cause an error. Now the reload of the runtime is correctly managed and the OPC UA Process Gateway continues to run after the runtime reloaded.
Issue Number: 29940
Fixed on Date: 5.7.2013
Versions: 7.00 0 BUILD 11
    • How to use certificates for OPC UA security
    • How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
      This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
    • How to setup the zenon OPC UA Process Gateway with a self-signed certificate
      This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
    • Checklist: Process Gateway cannot start
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
