When the process gateway is closed
after the runtime has been reloaded (compile all rt files
in editor) with the OPC UA process gateway running and a OPCUA client connected
(UAExpert on localhost, just connected), the OPC UA process gateway closes with an unhandled exception during "cleaning up", after the OPCUA process gateway was closed.
When no OPC UA Client is connected, the OPC UA process gateway closes normally.
Also when the runtime is reloaded, but no OPC UA client is connected, the OPC UA process gateway closes normally.
An issue was addressed in the OPC UA process gateway where the OPC UA process gateway could cause an error during closing when an OPC UA client was still connected
Issue Number: 29904
Fixed on Date: 5.7.2013
Versions: 7.00 0 BUILD 11
