OPC UA driver is not importing variables and extended objects correctly after update to zenon 10 build 111092 from build 94554.
The OPC UA driver does not import variables and
enhanced objects correctly. Especially the import of more than one structure is
affected. The error occurs in version 10 with builds higher than 94554
and in version 11. Up to build 94554 the import worked correctly.
This error has been fixed. The import works as
expected again.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 263037
Version: 11.00 Build: 157700
Version: 10.00 Build: 138660
