OPC UA driver communication issue when switching driver status from Simulation mode to Hardware mode while SE running
The OPC-UA driver does not communicate correctly with the OPC-UA server after switching from simulation mode to hardware mode and back to simulation mode while the Service Engine
is running and the OPC-UA server is not connected.
Variables get the status INVALID.
Even after the connection is established and the mode is changed again,
variables remain in INVALID status. Even
if the value of the variables is changed manually, the variables are seen as INVALID.
Switching to simulation mode again and back to hardware mode may enable
communication. Variables are then displayed with the correct status.
This behavior has been modified. When switching from
simulation mode to hardware mode or vice versa while the Service Engine is
running, all variables are displayed correctly.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 270099
Version: 12.00 Build: 206562
Version: 11.00 Build: 193390
Version: 10.00 Build: 195250
FAQ: How can I monitor and react on the communication status of my devices with zenon?
