When the browsename for variable of the OPCUA client driver is incorrect or does not match an item in the OPCUA server, the TranslateBrowseNameToNodeId request of the OPCUA client driver in the runtime results in an invalid NodeId "0" returned by the OPCUA server, with a corresponding error in the status code.
The OPCUA client driver does not correctly verify the status code for the received NodeID, and attempts every 500 ms to create a monitored item for the active subscrition with the NodeId "0", which fails on the server.
An issue has been addressed in the OPCUA client driver. When the Browsename does not result in a valid NodeId, in the translation repsonse, the driver now no longer tries to create a MonitoredItem with the NodeId 0. The driver now sends cyclically every 500ms a new translate request to retrieve the correct NodeId, when the item does become available on the server, so that a MonitoredItem can be created with the correct NodeID.
A corresponding error messge is logged in the Diagnosis Server that the BrowseName could not correctly be translated into a NodeId.
