On Windows CE devices the IEC61850 Server does not parse file transfer directory name with spaces
On Windows CE devices the IEC 61850 Server driver does not parse file transfer directory name with spaces. When a client sends GetServerDirectory service the driver logs "Client requested file directory [with '' on filesystem]."
Issue was addressed in determination of absolute path on CE-Devices.
Issue Number: 33496
Fixed on Date: 19.1.2015
Versions: 7.11 0 BUILD 17075
FAQ: Update CE proceedure
Checklist: Update CE fails
The OPCUA32 client driver does not communicate on Windows CE devices
Summary On Windows CE devices, the OPCUA32 client driver does not startup properly and does not communicate with the configured OPC UA server. The error logs in the diagnosis server contain the following error: "Failed to load client certificate" ... ...
FAQ: Windows CE not supported anymore with zenon! What are the main reasons and what do I have to consider? Is zenon not able to run on Windows CE anymore?
The support for zenon Windows CE Versions was frozen with the zenon Version of 7.20. This means that in any higher zenon version, the CE Version delivered with the Setup is a zenon CE Version of zenon 7.20. There are no more functional enhancements ...
Checklist: OPCDA Server
Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Do NOT use DCOM in combination ...
