On Windows 8 and Windows 10 Multi-Touch issue related to configured button as Momentary switch.
A button was configured as a Momentary switch with default status On. The operator touches the button with one finger and with a second finger touch on a blank location on the same screen. The operator lifted the finger from the button and let the other finger pressed. If then lifted up the finger from the blank location the status of the Momentary switch stays still on the default setting On.
 Now, also a button which was configured as Momentary switch works properly on Windows 8 and Windows 10 Multi-Touch environment.
Issue Number: 35894
Fixed on Date: 26.1.2016
Versions: 7.20 0 BUILD 25448 | 7.60 0 BUILD 36068
