on network client the status bit NET_SEL is sporadically not set when the command input screen has MDI-element 'Lock list'
Issue in zenon network on client: when user opens command screen via context menu and this screen includes MDI-element 'Lock list' then sometimes the status bit NET_SEL is not set. Then as the bit is not set the buttons in the command screen are disabled (grayed out).
Issue solved by an extension in the processing of initial values.
Issue Number: 30419
Fixed on Date: 27.9.2013
Versions: 7.10 0 BUILD 7770
