On a Webclient the userstatus value cannot be edited in the recipe value table in the Recipegroup manager screen
When editing a Recipegroup manager recipe on a webclient, in the recipe value table of the Recipegroup manager screen, the value for the userstatus cannot be edited.
An issue has been addressed in the Webclient where editing the userstatus column in the recipe value table could not be edited.
Issue Number: 31900
Fixed on Date: 12.5.2014
Versions: 7.50 0 BUILD 25796
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
The recipe value table in the Recipegroup Manager screen cannot be made invisible on a Windows CE device
Summary In the runtime on a Windows CE device, the recipe value table of the Recipegroup Manager screen cannot be set invisible through a variable. Description In the runtime on a Windows CE device, the recipe value table of the Recipegroup Manager ...
Recipe variables in the recipe value table in the Recipegroup Manager screen are not always correctly set invisible
Summary It can happen that Recipegroup Manager recipe variables are still displayed in the recipe value table in the Recipegroup Manager screen in the runtime, although the linked visiblity variable have an active limit with the invisible attribute ...
The sorting of the recipe value table in the Recipegroup Manager screen in the runtime changes unexpectedly under specific circumstances
Summary When selecting a recipe variable in the recipe value table in the Recipegroup Manager screen in the runtime and executing e.g. the screen specific function "read selected value", then change the sorting on a different column and executing the ...
