OmronEIP: If PLC is not accessible and Block read is enabled during during Runtime start, the Invalid bit" is not correctly set for all variables"
OmronEIP: If PLC is not accessible and Block read is enabled during during Runtime start, the "Invalid bit" is not correctly set for all variables
Issue Number: 183891
Fixed on Date: 14.5.2019
Versions: 8.00 0 BUILD 59775 | 8.10 0 BUILD 59911
Checklist: Engineering Studio cannot start or closes unexpectedly
Checklist: Process Gateway cannot start
Checklist: zenHelpService cannot start
Time estimate: 15 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. If during the installation of ...
FAQ: How can I monitor and react on the communication status of my devices with zenon?
Checklist: VBA Editor does not start neither wizards
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Check if zenWorkspace.vba is ...
