OMR_FINS driver does not read/write strings correctly from all memory areas
OMR_FINS driver does not read/write strings correctly from all memory Areas. Behavior is different depending on PLC type.
A new string data option for the driver has been provided: "First character is lo-byte". Default: FALSE .
As there are variations of Byte order in different Omron PLCs we now decided to implement an Option to select the Byte order for string data.
Issue Number: 34102
Fixed on Date: 26.3.2015
Versions: 7.10 0 BUILD 19354 | 7.11 0 BUILD 19853
