Occasionally, it is not possible to import a S7 project in the zenon 7.10 editor.
In the Import S7 project wizard it might happen that the step Select variables does not display any columns to show and select variables to be imported in the editor.
It has been addressed an issue in the zenon 7.10 editor so that Import S7 project wizard always displays columns to select and import variables correctly.
As a workaround, in the wizard Select variables step it is possible to add the columns manually by right-clicking over the grey top header and choosing the option Column selection... S7 project variables can be successfully imported afterwards.
Issue Number: 31286
Fixed on Date: 10.2.2014
Versions: 7.10 0 BUILD 11355
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
    • zenon logic: 1 gain FB with LD can't assign a structure to a structure
      Description In zenon Logic it was not possible to add a structure to a structure in LD. However, this is possible in ST and FDB. As a workaround, you can activate the "LD optimizations" option in the project settings in LD. This behavior has been ...
    • Checklist: Workspace/Project cannot be created, loaded or backed up
