Number of Alarms is wrong in AML screen if alarms from sub projects are included
In Multi-Project Administration, the number of alarms is
displayed incorrectly in the AML if more than one project is selected. If only one
project is selected, the number of alarms is displayed correctly.
As soon as
the integration project and a subproject are selected together, only the alarms
of the integration project are displayed. The alarms of the subproject are ignored. This issue has been present since
version 11.
This error has been fixed. In the AML, the
number of alarms is displayed correctly again when several projects are
selected.
higher.
Item ID: 264562
Version: 11.00 Build: 157700
opening AML screen with many alarms (including subprojects) causes a freeze
Description When opening an AML screen with very many entries, the system freezes. Cause: In this case, the alarm ring buffer contains a very large number of alarms (several tens of thousands). If they are no longer active when the Service Engine is ...
FAQ: How to troubleshoot and resolve High CEL Log volume
Diagnosis: Identify the offending variables To address high Chronological Event List (CEL) log volume, first identify which variables are generating excessive events. Open the CEL screen in the zenon Service Engine (Runtime) (or in File Inspector). ...
MSI Interface: The response to an Exception Request includes historic and non historic alarms
Description If historic alarms should be retrieved from the MSI Interface, the response included historic alarms and alarms which are defined as non-historic. The issue has been addressed and now the response only includes historic alarms. To benefit ...
