Not all Alarm Conditions are forwarded from the OPC UA server
Alarm conditions are only forwarded in OPC UA server if they come from a projected limit. When the alarm condition is generated with a reaction matrix it is not considered in the OPC UA server.
Alarms generated with the use of reaction matrices are now also supported in the OPC UA server
Issue Number: 23750
Fixed on Date: 25.2.2013
Versions: 6.51 0 BUILD 20 | 7.10 0 BUILD 5560
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
    • How to use certificates for OPC UA security
    • OPC-UA Server: DNS Name used in certificate created by zenon.
    • How to setup the zenon OPC UA Driver with a CA-signed certificate
    • How to setup the zenon OPC UA Driver with a self-signed certificate
