None of the ServiceGridGateway executable files are signed
Executable files for the installation of Service Gateway
(formerly known as Service Grid Gateway) were not digitally signed in some
setups for IIoT Services from version 11.2 upwards. This could make the
installation of the zenon Software Platform difficult or impossible.
This error has been fixed. All executable files are
digitally signed again.
- Update your zenon Software Platform to the latest build of zenon 11.2 or
higher.
Item ID: 267160
Version: 12.00 Build: 159727
Not all executable files (Dll, exe) installed by the build setup are digitally signed.
Summary All executable files should be digitally signed with the current Ing. COPA-DATA Punzenberger GmbH software signing certificate to prove authenticity. The build setup may contain executable dll or exe files that are not digitally signed. ...
FAQ: How to prevent corrupted files after power outage?
Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
FAQ: How to import external vector graphic files in zenon?
Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
ThreeDElement files are deployed unsigned
Description The listed files in the BUG were deployed unsigned. The issue has been addressed and the listed files are signed now before the deployment packages are "created". To benefit from this fix: Update your zenon Software Platform to the latest ...
FAQ: Update CE proceedure
