No warning when overwriting archive values with the help of the Metering Point Administration
The Metering Point Administration allows to write values into an archive by entering a new manual value or by entering a meter replacement. In the latter case it would, however, not display a warning in case there already exists an entry with the provided time stamp. This may lead to unwanted overwriting of archive data.
A validation has been implemented to avoid unwanted overwriting of archive values in the described scenario. After the fix a dialog is displayed in which the user can choose to overwrite or not to overrite the aleady existing value.
Issue Number: 33955
Fixed on Date: 19.3.2015
Versions: 7.50 0 BUILD 25796
