Multiuser projects are excluded from the Metering Point Administration. However, the the Metering Point Administration may still modify the project´s IMM database configuration.
when starting the metering point administration with a multi-user project in the workspace, the wizard correctly identifies the multi-user project and informs that this project will not be available. However, during the check of the IMM configuration the project will still be used. If the configuration does not match, the dialog to accept the modification is displayed.
The described issue has been resolved. The Metering Point Administration will no longer check the IMM database configuration of multi user projects, nor modify it.
Issue Number: 35047
Fixed on Date: 30.5.2017
Versions: 7.60 0 BUILD 36068
