Multiple replacement strings for the linking rule of symbols do not always result in the correct variables being replaced
Under specific circumstances multiple search strings for the linking rule for symbols do not result in all variables being replaced correctly.
An issue has been addresed in the replacement of variables through linking rules for symbols when using multiple search strings, separated with ";"
Now when variable names are used in the symbol that partly have the same characters, the variables are correctly replaced when search strings have the same beginning characters
Issue Number: 34119
Fixed on Date: 16.4.2015
Versions: 7.10 0 BUILD 19354
    • Multiple replacement strings for the linking rules for symbols do not work correctly
      Summary When configuring a linking rule for symbols using multiple replacement strings separated with ";" the replacement does not always work correctly Description When configuring a linking rule for symbols using multiple replacement strings ...
    • HTML Web Engine doesn't display replaced variables via multiple linking rules in symbols
      Summary There was no support implemented in the WebEngine for multiple entries in the linking rule substitution. This was now fixed. Description There was no support implemented in the WebEngine for multiple entries in the linking rule substitution. ...
    • Variables used in embedded symbols are not always correctly listed in the project analysis
      Summary When using variables in embedded symbols these variables are not always correctly listed in the project analysis window. Description When using variables in embedded symbols these variables are not always correctly listed in the project ...
