Multi-user client project: It is not possible to create new variables & datatypes in a project created in an earlier zenon version and the OS uses Istanbul timezone
Variable cannot be created in Istanbul time zome under special cicumstances
To use a different timezone when possible.
Issue Number: 217912
Fixed on Date: 25.5.2020
Versions: 8.10 0 BUILD 66325 | 8.20 0 BUILD 66111
    • Multi-user client project cannot synchronize when the Operating System uses Istanbul timezone
      Summary Creating multiuser projects does not work if timezone is Istanbul Description Creating multiuser projects does not work if timezone is Istanbul Issue Number: 217104 Fixed on Date: 14.5.2020 Versions: 8.10 0 BUILD 65969 | 8.00 0 BUILD 66110 | ...
    • FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
      When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
    • Checklist: Workspace/Project cannot be created, loaded or backed up
