[MSI Interface] Sending an Exception Message freezes the Service Engine
If an exception message is triggered in the Werum MSI Interface for which an
identifier is defined, the Service Engine can freeze. Identifiers enable the
correct assignment of the exception message to the linked property.
This error has been fixed. Exception messages can be
triggered again as expected.
higher.
Item ID: 268610
Version: 12.00 Build: 180966
Version: 11.00 Build: 165844
[MSI Interface] Sending a Exception Message leads to XML deserialize Error
Description Configured exception messages are not sent in the Werum MSI Interface. This was caused by an XML deserialization error. This error has been fixed. Exception messages are sent again. To benefit from this fix: Update your zenon Software ...
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
[MSI Interface] Deleting an Alarm Event Group prevents sending of Exception Messages
Summary In the Werum MSI Interface, deleting an alarm/event group leads to an error under certain conditions. This has been fixed. Description In the MSI configuration an alarm/event group is used to define an exception message. Later, a group is ...
