[MSI Interface] Number format from the Operating System configuration, not supported by the MSI, prevents message from being sent correctly
The number format from the operating system configuration which is not supported by the MSI Interface, prevented the message from being sent correctly.
The issue has been addressed and the message is sent now correctly.
Item ID: 289789
Version: 14.00 Build: 330575
    • Checklist: Printer does not print in the format as expected
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. No .frm file is used to specify ...
    • [MSI Interface] Deleting an Alarm Event Group prevents sending of Exception Messages
      Summary In the Werum MSI Interface, deleting an alarm/event group leads to an error under certain conditions. This has been fixed. Description In the MSI configuration an alarm/event group is used to define an exception message. Later, a group is ...
    • [MSI Interface] Missing reload when restoring addin configuration/messages prevents the messages to be sent
      Description Due to a missing reload in case of restored Add-In configurations/messages the MSI Interface did not send messages. The issue has been addressed and a reload ensures now, that the messages are sent. To benefit from this fix: Update your ...
