[MSI Interface] Long loading times in the Config dialog
When configuring the Werum MSI Interface, the configuration dialog takes a very long time to load. This can be caused by a large number of exception messages.
This behavior has been modified. The number of API calls made when opening and using the configuration tool has been reduced. The loading time for medium and large projects when using the configuration tool has been significantly reduced.
Item ID: 269460
Version: 11.00 Build: 182164
Version: 12 Build: 180966
