[MSI Interface]: Invalid Token Request
The Werum MSI Interface cannot communicate with the PAS-X
adapter version PASX2X v4.3.0 or
higher. An invalid request is sent. Thus, the MSI Interface
does not receive a token. Therefore, no messages can be sent to PAS-X.
This error has been fixed. The Werum MSI Interface
now sends requests that are accepted by the PAS-X
adapter of version PASX2X v4.3.0.
higher.
Item ID: 265973
Version: 11.00 Build: 157700
MSI Interface: The response to an Exception Request includes historic and non historic alarms
Description If historic alarms should be retrieved from the MSI Interface, the response included historic alarms and alarms which are defined as non-historic. The issue has been addressed and now the response only includes historic alarms. To benefit ...
MSI Interface: Language table support
Description [Feature]: The MSI Interface did not support Language tables The functional gap has been addressed and the MSI Interface now supports Language tables in a way that it is possible to configure the desired language in which the content of ...
MSI Interface: Extending Exception Messages
The graphical user interface of the configuration dialog for the configuration of exception messages has been revised. The Exception Message Configuration dialog can now be opened directly when selecting the Exception Message tab. The dialog is ...
MSI Interface: Message handling part 2
Description [Feature]: The processing of MSI Interface messages has been further improved. The functional gap has been addressed and the MSI Interface Message handling has been improved: trigger values on startup/restart can be ignored, a reset value ...
MSI Interface: Adding Fields to Parameters
The configuration of Order Parameter Messages has been expanded and revised: Revision of the graphical user interface in the Order Parameter Message Configuration dialog. The parameters are now displayed in tabular form. The options are configured ...
