[MSI Interface] Exception Queue is not saved
If a separate data folder was used, the Message Exception Queue was not saved and was not available after a restart.
The issue has been addressed and the Message Exception Queue will be saved now also, if a separate data folder is used. This is possible via the new properties Service Engine folder and Data folder.
  • Update your zenon Software Platform to the latest build of zenon 12 or higher and update the MSI Interface AddIn in your project.
Item ID: 298175
Version: 14.00 Build: 393950
Version: 12.00 Build: 397336
