MSI Interface: Adding Fields to Parameters
The configuration of Order Parameter Messages has been expanded and revised:
  • Revision of the graphical user interface in the Order Parameter Message Configuration dialog.
    • The parameters are now displayed in tabular form.
    • The options are configured per table row.
    • If the Range from variable property is active, the limit values for signal range min. and signal range max. are taken from the parameter variable.
  • In addition, new parameter options have been added to the Order Parameter Message Configuration configuration dialog.
    • SF qualifier
    • Limits from variable
    • UOM (Unit of measurement)
    • Optional
    • Value can be empty
      Attention: These parameter options are only available for certain PAS-X versions. The new Target MSI Version option has been implemented in the Configuration dialog for this purpose. The configuration of this option determines the MSI Interface version for which valid Order Parameter Message Definitions can be created.
Item ID: 273699
Version: 14.00 Build: 293273
