MQTT - segmentation fault when the you connect to a brocker with bad certificate.
In the Logic Service, if a connection to a broker with an invalid certificate is established, the Logic Service is terminated unexpectedly with a segmentation fault.
This bug has been fixed. The Logic Service is no longer terminated unexpectedly.
Item ID: 279750
Version: 14.00 Build: 239777
    • OPCUA Server - Segmentation Fault when client authenticates using non-existent certificate
      Description The OPCUA Server encountered a Segmentation Fault when the client authenticated itself with a non-existent certificate. The issue has been addressed and the OPCUA Server no longer runs in a Segmentation Fault if a non-existent certificate ...
    • How to setup the zenon OPC UA Driver with a self-signed certificate
    • How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
      This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
