MPA Error Message Calculate Relative Value Active
An error occurs in Metering Point Administration when calculating relative values for archives. A message is displayed that the Project ID could not be found. This mainly occurs if zenon 8.20 is installed on a system on which a lower zenon version has already been installed.
This error has been fixed. The calculation is performed as expected again.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 242779
Version: 10.00 Build: 97200
