Moving locked variables from global to retain using multi-select does not work in the workbench
Variables that are set "externally visible" in the zenon editor are locked in the zenon logic workbench and cannot be moved from GLOBAL to RETAIN using multi-select in the zenon workbench.
An issue has been addressed in the zenon logic workbench where drag&drop of locked variables using multi-select did not work correctly.
Issue Number: 20873
Fixed on Date: 8.3.2015
Versions: 7.10 0 BUILD 5560
    • Under Windows CE retain variables in zenon logic are not loaded.
      Summary Under Windows CE retain variables in zenon logic are not loaded when: stopping/starting from zenon logic workbench stopping/starting the zenon logic runtime compiling and downloading with stop/restart of the Project on the CE7 / ARM processor ...
    • Alarm aggregation via equipment modell using alarm classes from global project does not work
      Summary Linkage to alarm classes is now id based also in the equipment model groups. So it also works with alarm classes for global project. I did the same for all the variables that can be linked to a group (not only alarm linkage but also for net ...
    • zenon Logic: Sporadic data loss on retain variables
      Description Retain variables were not loaded on startup because an invalid retain file was written when the retain file exceeded 256 KB with retain-by-name enabled. The issue has been addressed and the behavior is now as expected. To benefit from ...
