Monitoring tool wizard crash (wizard for generating K5M file)
In the zenon Logic assistant "Generate Monitoring Application", an error message with a white X in a red circle is displayed on the "Select typeof tree" page when clicking on ">Next". If this error message is acknowledged with "OK", the list of POUs on the following page is incorrect.
This bug has been fixed. The configuration will run correctly again.
Item ID: 284195
Version: 14.00 Build: 257014
