When starting a project with another language as developed, for example a project was created in the favor language of the project developer (e.g.: English) and started afterwards in another language (e.g.: Russian) compile and start the zenon Runtime, it could be that an Error Message – ‘Exception in Wnd’ arise.
An issue was addressed at the Monitor Profiles. Now, the default name ‘Standard’ is no longer language dependent.
Reason for this ‘Exception in Wnd’ is that project was created with English Editor and therefore standard monitor profile is called ‘Standard’. Unfortunately this default name is language translated and no longer called ‘Standard’ in Russian. This causes the Exception error.
Workaround:
1) Rename monitor profile "Standard" into e.g.: Russian translation of standard ("????") or
2) Select monitor profile "Standard" on the zenon Runtime PC (or set corresponding zenon6.ini entry to "Standard")
Issue Number: 34283
Fixed on Date: 23.4.2016
Versions: 7.50 0 BUILD 25796
