The Metering Point Administration creates some zenon logic code to calculate the relative values. However, if either the absolute value variable or the relative value variable has special characters (like ä, ü, etc.) in its name, then the generated zenon logic code is invalid and can´t be compiled.
An issue has been fixed where special characters have not been inserted into the zenon logic code correctly. After the fix, variables with special characters in their names may be used in the Metering Point Administration without any issues.
Issue Number: 35084
Fixed on Date: 8.4.2016
Versions: 7.20 0 BUILD 27570 | 7.50 0 BUILD 27465
