Messages are not sent properly when using "Following Call" and user group name from string variable
If desired user group name for "Send Message" function is taken from a variable, the first user receives a message. If this message is not acknowledged, the next user does not receive a message and the following CEL entry is created: "End of group reached (following call).
An issue was addressed in the message control module which prevented new messages to be sent. Now, messages are sent to the next users in line if the first user does not acknowledge a message.
Fixed on 29.11.2012, available from 7.00 SP0 Build 5
Issue Number: 28123
Fixed on Date: 29.11.2012
Versions: 7.00 0 BUILD 5
    • Message Control sending method Following Call and Endless Call do not work properly
      Summary When the sending method Following Call and Endless Call are used in a Message Control Send Message function, the group is not run through. The Message Control MDI screen reports that an error during sending has occurred, although a message ...
    • Send Group, Following Call and Endless Following Call messages don't recognize MC users
      Summary Message Control Send Message function does not work for user groups in the runtime properly. Also see #26855. Description Message Control Send Message function does not work for user groups in the runtime properly. Also see #26855. Solution ...
    • Empty 'variable name' column in CEL for messages from RGM
      Summary The Recipe Group Manager, when writes a recipe, creates in the Chronological Event List entries where 'text' contains name of the recipe, new and old values of the variables and names of the variable. But the column 'variable name' of such ...
    • MSI Interface: Extending Exception Messages
      The graphical user interface of the configuration dialog for the configuration of exception messages has been revised. The Exception Message Configuration dialog can now be opened directly when selecting the Exception Message tab. The dialog is ...
    • MSI Interface: Extending Exception Messages II
      Exception Messages can contain additional information. To this end, the Exception Message Configuration dialog has been enhanced: New Append to system description option group. The following information can also be added to the system description: ...
