Messagecontrol: VOIP message is not forwarded to the subsitute person or in a following call when the first person in charge is not responding (no reaction)
VOIP messages in Message Control are not forwarded. This behavior has been fixed.
In Message Control, if a VOIP message is not not answered by the first person called or the call is answered by an answering machine, then the call is not forwarded to the replacement person nor is the call repeated.
This behavior has been changed.
  • Update your zenon Software Platform to the latest build of zenon 8.10 or higher.
Item ID: 249529
Version: 12.00 Build: 162090
Version: 11.00 Build: 161931
Version: 10.00 Build: 160372
Version: 8.20 Build: 99641
Version: 8.10 Build: 99638
    • Messagecontrol: VOIP message is not forwarded to the subsitute person or in a following call when the first person in charge is not responding (no reaction)
      Summary User substitution will be processed after the hardware timeout . Description User substitution will be processed after the hardware timeout . Issue Number: 249529 Fixed on Date: 19.5.2022 Versions: 8.10 0 BUILD 99638 | 8.20 0 BUILD 99641 | 10 ...
    • FAQ: Message Control || VoIP message is sent but can’t be heard
      In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
    • Fritz!Box VoIP: Voice transmission fails
      Summary When using a Fritz!Box, the voice transmission via Message Control fails. This has been fixed. Description A transmission error occurs with Message Control when using VoIP with an intermediary VoIP server such as the Fritz!Box. Cause: An ...
