Message Control SMTP sending type: Not robust against lagging SMTP connection
The message control engine tried to send the EHLO before the received server greeting was fully received (due to lagging connection - there was just one receive attempt without timeout). Now, the engine uses a 10 second timeout for completely receiving the server greeting (both SMTP and POP connection either continue when the server greeting was received or abort after the timeout).
Issue Number: 226462
Fixed on Date: 9.9.2020
Versions: 8.10 0 BUILD 68622 | 8.20 0 BUILD 68579
Checklist: Message Control
Message Control SMTP Encrypted sending type not robust against laggy network connection
Summary When the SYN-ACK is received with a delay higher than 100ms, openSSL reports "connecting failed - no more retries". Added a logical retry loop: in this case wait 1 second and then retry (max 3 attempts) to resolve this. Verified by debugging: ...
FAQ: Send and receive Email via SMTP does not work
Many email providers require the use of app passwords when accessing their services through third-party software. If you need to use SMTP or POP3 (or IMAP) to access your email, you will need to generate an app password specifically for that ...
E-Mail Messages sent from Message control with SMTP cannot be acknowldged correctly.
Summary E-mail messages sent from Message Control with SMTP cannot be acknowledged correctly by replying to the e-mail. The e-mail in the inbox is correctly detected, but the message is not acknowledged DescriptionE-mail messages sent from Message ...
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
