The projected PIN and NA code in the Send Message function should have higher priority that the ones set in the user administration. Although the correct PIN / NA code is entered in the acknowledgement, Message Control reports that the wrong one is used.
An issue was addressed in the Message Control module that used the PIN / NA code projected in the User Administration no matter if another PIN / NA code was used in the Send Message function. Now, the correct code is taken for acknowledgement.
Fixed on 08.05.2012, available from 7.00 SP0 Build 1
